The name 180SX was originally in reference to the 1.8 liter displacement CA18DET engine used in the chassis. In 1991, however, the engine was upgraded to a 2.0 liter model, offered in two forms: the naturally-aspirated SR20DE engine and the turbocharged SR20DET variant. Although the new engine was of larger displacement, the 180SX nomenclature remained. A common body modification to the 180SX and its sister car, the North American 240SX fastback, is the Sileighty conversion.
180SX was also a trim level of the S110 Silvia in Europe. The badges for this model read "Silvia 180SX", so this car is not properly a 180SX by model, but a version of the Silvia instead.
Other discrepancies from this standard were distributed to Micronesia and South Pacific islands, including LHD cars with 180sx badges and non-retractable headlamps.
Like the Japanese 180SX SR20DET discrepancy, European, as well as South African models of the S13 chassis were called 200SX though equipped with the CA18DET engine.
180SX Model Changes
An early model 180SX.The 180SX came in three major iterations, the first of which was released in March 1989 and the last of which ended production in December 1998.
The first iteration of the 180SX came in two versions called Type I (standard type) and Type II (advanced type). Nissan's HICAS II four wheel steering system was optional only on the Type II 180SX. All versions had the CA18DET engine with 175ps. 5 speed manual and 4 speed automatic transmissions were available in all types.
The second iteration 180SX was released in January 1991 and boasted several major changes from the first model. The biggest change was the adoption of the SR20DET engine with 205ps. Although the engine was larger than the previous CA18DET engine the '180SX' nomenclature remained. The brakes were enlarged to cope with the increased power as was the limited slip differential. The front bumper and parts of the interior were also redesigned for this model. Type I and Type II were once again offered with only trim differences separating the two. The 15-inch alloy wheels also changed in design from the first model. Nissan's Super HICAS four wheel steering was an option on all models as were 5 speed manual and 4 speed automatic transmissions.
The final 180SX, showing the revised tail lights, spoiler and rear trims.The second iteration was face-lifted in January 1992. Although the car largely remained visually and mechanically unchanged, an additional trim level called Type III was added. Electronic climate control and CD audio were also added as options.
An additional face-lift was performed in 1994, the trim levels were renamed to Type R and Type X, with Type X being the higher of the two. Overall the car remained almost unchanged however.
A finally face-lift to the middle model occurred in May 1995 with the addition of a drivers side airbag and a change of alloy wheels amongst other minor details.
The final iteration was released in August 1996. It boasted a revised front bumper, tail lights, 15-inch wheels and interior. The mechanical and safety package received minor changes, such as the addition of a driver’s side airbag, seat belt pre-tensioners, and some changes in the wiring and ECU that had little to no impact on the actual performance of the car. Three levels of 180SX were offered: Type X, Type S and Type R, with the Type S being the first 180SX to be offered without a turbocharged engine.
The Type X and Type R both shared the same 205ps engine and overall mechanical package however the Type R lacked many of the cosmetic additions of the Type X such as the rear spoiler, side steps and 15-inch alloy wheels. The Type S was powered by a naturally aspirated SR20DE engine with 140ps, but was otherwise very similar in mechanical and cosmetic details to the top of the range Type X. The Type S however did not have the option of Nissan's Super HICAS four-wheel steering system like the turbocharged models did.
The Type X and Type R ceased production in October 1997 however the Type S and an addition naturally aspirated model called the Type G continued production until December 1998 when all 180SX production ceased.
Takže až se příště budete bavit o Nissanu Silvia S13 už budete vědět, že se jmenuje 180SX protože k tomu "přejmenování" na 200SX došlo jen z důvodů kvůli homologačním řízení v některých státech (typicky Evropa a jižní Afrika)
