Prodam bud jednotlive, nebo v sade. Na CA18DET.
Maximum Horse Power 350-400 HP
Inlet size 3"
Outlet size 2"
Type of Cooling Oil Cooled only
Maximum PSI Capactiy 25 PSI (Default set at 14.5PSI)
Type of bearing Wet float bearing
Compressor/turbine size AR.60/AR.84
Compressor wheel Exducer: 71.32mm, Inducer: 54.28mm
Turbine wheel Inducer: 52.90, Exducer: 45.47mm
Downpipe flange type 5 bolt (SR20/CA18 downpipe)
Type of Flange T25 Flange
CENA MANIFOLD 3.600Kc
CENA TURBO 9.900Kc
CENA KOMPLET 13.000Kc
CA18DET
Maximum Horse Power 325-350 HP
Inlet Size 2.5"
Outlet Size 2.25"
Type of Bearing WET FLOAT BEARINGS
Oil inlet Size 1/8 NTP
Maximum PSI Capacity 23 PSI
Compressor .42 AR Compressor
Compressor wheel exducer: 60.41mm/ inducer: 43.20mm
Turbine .48 AR Turbine
Turbine wheel inducer: 62.86mm/ exducer: 45.74mm
Type of Flange T3
Type of Down Pipe Flange 5 bolts
CENA TURBO 10.600Kc
CENA KOMPLET 13.600Kc
Svody Goodspeed teflon
CENA 3.900Kc
P: Goodspeed manifold + turbo
- nismo.gtst
DRIVE:
Re: P: Goodspeed manifold + turbo
k tym topmout zvodom mas aj outlet?
spoutu dilu s12,s13,s14
My cars
Skyline R34 white
570sx s13 swap LS1
[TEL 0907111900
My cars
Skyline R34 white
570sx s13 swap LS1
[TEL 0907111900
- nismo.gtst
kdyby ano, tak je to tam vyzobrazeno, nebo napsano, ne? da se doobjednat...slik85 píše:k tym topmout zvodom mas aj outlet?
autobahn, japspeed stoji okolo 1800set
DRIVE:
