Z32 Váha vzduchu do SR20DET
potřeboval bych poradit jak se mám zapojit konektor , u váhy z Z32 je o kabel navíc.
Pinout for the RB20/25/Z32 AFM is:
Pin A - nothing
Pin B - air flow signal Out
Pin C - ground (karoseria)
Pin D - ground
Pin E - +12v power
Pin F - nothing
These start from the front (air in) of the AFM, and pins A or F can be missing (RB20/25s generally won't have pin F at all).
On the SR and CA AFMs the pinout goes:
Pin A - nothing / not needed
Pin B - +12v power
Pin C - ground
Pin D - air flow signal out
Pin A - nothing
Pin D - ground
Pin E - +12v power
Pin F - nothing
Pin B - +12v power
Pin C - ground
