P: V8 JIZ NENI AKTUALNI
Napsal: 29.03.2011, 07:04
Kdyby chtel nekdo na stavbu neceho sileneho
Motor Chevy 454 7.4 V8 novy. Bez toho sani na fotce, to je pro kompresor. Vykon 500hp pri pouziti 800cfm karbce. Je moznost koupit i sani pro EFI. Spodek je stavenej na 1000hp, takze pri pouziti nejvetsiho kompresoru od Weiandu bude vykon kolem 750-800hp. Vice na email ci tel.
sejkoramartin@gmail.com
777704145
-DART BIG M 454 aftermarket engine block - NEW
-HP cast iron heads - OEM heads with a new angle job done
-MANLEY stainless steel valves - NEW
-COMP CAM springs - NEW + ARP studs - NEW
-SCORPION 1.7 rockers - NEW
-ARP head studs -NEW
-Aluminum valve covers – NEW - modified
-EAGLE rotating assembly ( forged pistons, H beam connecting rods, forged steel crank ) - NEW
-ARP main bolts ) - NEW
-LUNATI hydraulic roller cam 50249LUN - NEW
-COMP CAM hydraulic lifters - NEW
-COMP CAM push rods - NEW
-HORSCHEL fluid damper - NEW
-PETE JACKSON timing gear drive - NEW
-Aluminum timing cover - NEW
-EDELBROCK aluminum water pump with aluminum pulley - NEW
-MARCH PERFORMANCE aluminum steering pump with aluminum pulley + stainless bracket - NEW
-High volume oil pump - NEW
-MILODON oil pan - NEW
-MSD distributer - NEW
-SUMMIT small starter up to 16 : 1 compression ratio - NEW
-FEL PRO gaskets set for whole engine and in addition a pair of soft coper head gaskets - NEW
-Hooker Headers, modified to fit corvette chassis - NEW
777704145
