P: T25G prodáno
Napsal: 12.06.2011, 23:28
od Fizzbiker
T25G ma AR .80 kompresoru a AR .64 Turbíny
The T25G is the next generation T25 that came out on the SR20DET S13 cars.
The only difference is a larger Exhaust housing and fins allowing slightly more boost to be held at top end with a lil less inlet temps.
If you can pick 1 up cheap, go for it! its a quick easy upgrade, but still wont be to fantastic over 15psi just like the normal T25.
On a standard DET with stock ECU, injectors etc, this turbo will be enough to net you around 230-250bhp@14psi
cena 4999,- Kč tak jak je na foto tzn i s začistěnou outlet připravenou na omotání a s ořízlým T28 intlet aby to šlo cele napasovat na CA, stav rekl bych oki, bral sem ho do zemiho asi pred rokem a jeste sem to na aute nemel cekalo na novy motor.
Re: P: T25G
Napsal: 12.09.2011, 09:52
od Fizzbiker
prodáno
