Dalsia otazke je, ci bude to auto pojazdne aj bez dalsich uprav (palivova pumpa, chip, afm), ktore planujem neskor. Za ten cas by som chcel jazdit (samozrejme, ze s rozumom). Plus ci sa daju u nas (myslim tym aj CR
Zatial diky.
DobrýPeca píše:Buhehe, ten týpek popisuje výměnu turba následovně :
I can describe the removal as follows. Imagine sitting under your car, assume a sit up position and hold for 2-3 hours. Get someone to poke your head with a sharp object and drop a spanner on your face every five minutes. Then imagine someone gently urinating coolant in your eyes and hair at sporadic intervals. Finally poke yourself in the eye with a stick a couple of times. You have now experienced the physical sensations of this job.
Asi to není taková pohoda jak tu chlapi píšete
Nezdá se ti toblázen píše:nema Howado nějake takove turbo v autě? nebo se mi to zda?
