Vačky
spavo
Vačky
Příspěvek od spavo »
Nevie niekto nahodov kolko stupnove vacky su v 200sx s13 1,8t ca 18? A ake ostre vacku su v sunny 1,6gti alebo 1,8Gti
EURO spec CA16DE...
In lift - 8.5mm
Ex lift - 8.5mm
In duration - 248
Ex duration - 248
In opens - 15 BTDC
In closes - 53 ABDC
In center lobe angle - 109deg
Ex opens - 59 BBDC
Ex closes - 9 ATDC
Ex center lobe angle - 115deg
EURO spec CA18DE...
In lift - 8.5mm
Ex lift - 8.5mm
In duration - 248
Ex duration - 248
In opens - 16 BTDC
In closes - 52 ABDC
In center lobe angle - 108deg
Ex opens - 50 BBDC
Ex closes - 18 ATDC
Ex center lobe angle - 104deg
EURO spec CA18DET...
In lift - 7.8mm
Ex lift - 8.5mm
In duration - 240
Ex duration - 248
In opens - 0 BTDC
In closes - 60 ABDC
In center lobe angle - 120deg
Ex opens - 59 BBDC
Ex closes - 9 ATDC
JPN spec CA18DE S13...
In lift - 7.8mm
Ex lift - 8.5mm
In duration - 240
Ex duration - 248
In opens - 0 BTDC
In closes - 60 ABDC
Ex opens - 59 BBDC
Ex closes - 9 ATDC
JPN spec CA18DET S13...
In lift - 7.8mm
Ex lift - 8.5mm
In duration - 240
Ex duration - 248
In opens - 0 BTDC
In closes - 60 ABDC
Ex opens - 64 BBDC
Ex closes - 4 ATDC
Ex center lobe angle - 120deg
spavo
DAkujem...
